Radio remains keyed if slice closed during TUNE
Greg Zenger [N2GZ]
While using the TUNE feature to output a carrier on Slice A, I accidentally closed slice A. (don't ask what possessed me to do that, I couldn't tell you). The result was the the radio remained keyed and transmitting a carrier. Clicking TUNE did not **** the carrier.
I added another slice which replaced Slice A (I had a Slice B open) and clicked tune and the radio remained keyed. I was finally able to **** the carrier by clicking the MOX button. This however left the radio in an awkward state where the Tune Button was still Blue.
With a dummy load attached I have been able to recreate the problem. I also observed the following:
If only one slice (Slice A) is open and I click Tune and close the Slice A, I can open a new Slice A (which does not open on the frequency of the transmitted carrier) and click the TUNE button the radio stops transmitting. However, the radio is now in a "confused" state Where Slice A shows as being the selected TX slice, however the status bar down by the GPS Status and Clock shows TX Not Selected. Clicking TX on Slice A (Two clicks), restores the radio to operational status.
FLEX-6700
SSDR 1.3.8.126
FLEX-6700
SSDR 1.3.8.126
The same thing occurs if you close the client during TUNE.
73, Ray, K9DUR
Is there a watchdog timer on radio<-->client communications?
And should there be a "restore to idle-state" button in the client software for instances like these where the watchdog hasn't timed out but the TX needs to be killed?
Steve
K9ZW
This is most probably a software defect. I have added it to our bug tracker for further investigation.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
