Flex 6300 Microphone pin outs
If it is like all the other Flex radios ... the pin out is Yeasu
I just confirmed it ... And here is Tim's answer... Yeasu.1 -
Ernest and I should enter the Olympics if they ever have a synchronized typing event.
You can skip the pins that you don't use but make sure you put then together and ground them so that you don't have RFI antennas. I have had great luck with the Heil shielded mic cable in keeping RFI at bay.
As I recall, the hand mic provided by FRS is a Yeasu product. I use a **** mic with the Heil mic cable. Use the cable with the orange sleeve on the mic xlr connector. Works perfectly for me.
Flex is the same as Yeasu for both the 8pin RJ45 and the 8 pin mic plug.
va3mw0 -
Thanks Everyone. Now I have Configure my Mic switch panel (It's setup for Kenwood Mics) so I can adapt it to the Yeasu cable. Should be simple enough. I do have a Flex 3000 but it has a 8 pin RJ45 connection.
George N1NAZ0 -
I need to thank several of you! I have been struggling to get an MFJ voice keyer to work with my Heil PR781 on my Flex 6300. Set all the jumpers the way the pin outs made sense and got nothing. I went back and set all the jumpers for Yaesu since you said it was the same. Chalk this one up to stop reading the manual!
I have the MFJ 434B recording and sending as it should, but I am getting a lot of hum. Any ideas?
THX
I have the pinouts in the MFJ now so that using the external Heil PR781 is clean on xmit, BUT when I try and record an outgoing message I get a ton of static in the background and a hollow sound.
Any more ideas or help please.
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
