Anti-Vox
Alan Nusso, N4BV
edited June 2020 in New Ideas
Anti-Vox is needed in SSDR. The lack of it makes using Vox with speakers a real problem.
It would be a very welcome addition to this wonderful radio!
0 votes
In Review · Last Updated
  • John n0snx
    John n0snx Member
    edited April 2015
    I am not a VOX user but I believe you can adjust the DEXP to solve the problem
  • Steve W6SDM
    Steve W6SDM Member ✭✭✭
    edited December 2014
    The fox sensitivity is adjustable . Also, speaker placement can help with unwanted VOX tripping.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Anti-VOX will be a difficult implementation because there are multiple sound sources and stereo speakers to account for. Sampling all those different levels and then blanking them from the mike will be a tough programming project. Ken - NM9P
  • Steve W6SDM
    I should not type after too much coffee.  I mean, the VOX is adjustable as far as sensitivity, which pretty much accomplishes the same thing as an anti-VOX, right?
    My speakers are within a two feet of the mic and I don't have a problem.  What I do have a problem with is when the dogs go on red alert because the UPS guy is dropping off a package.  A friend in Hawaii calls it the bark heard around the world.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited February 2018
    It is a sensitivity thing, when adjusted ok it should work well. It always works very well on my Flex 3000, once I get it setup right.
  • SteveM
    SteveM Member
    edited December 2015
    This is the echo-cancellation problem. The solution is usually some flavor of adaptive filter in echo-cancelling mode. It's been done to death. Implementations are available.
    I agree with the OP. Sensitivity-adjustment is the brute force solution and may only be adequate for use with headsets.
