Mfj 993b
Tony Hateley
Tony Hateley Member ✭✭
edited January 2017 in FLEX-6000 Signature Series
Is it possible to interface a mfj 993b to the flex 6500.thanks
  • Ricky
    Ricky Member
    edited February 2015
    Why would you want to do that as the tuner in your radio is much better then the MFJ ?
  • Steve W6SDM
    Steve W6SDM Member ✭✭✭
    You can, especially if you didn't get the internal tuner option or if you are running an amp.  However, a much better external tuner is the Elecraft KPA500.  It's an automatic band switching memory tuner that keeps you from having to tune when you change bands.
  • Tony Hateley
    because the mfj has memories and intellitune
  • Dale KB5VE
    Dale KB5VE Member ✭✭
    edited January 2017
    Several of us have the mfj 998 how would you hook the cable up to the radio and tuner.
  • Tony Hateley
    the elecraft kpa500 is a amp not a tuner or am I wrong
  • Steve W6SDM
    edited December 2014
    Yeah, a typo.  I have the KAT500 tuner AND the KPA500 amp.  They both work great with my 6300.
