SSDR Stops Running
RoyS
Yesterday, the 16th, after running for about 7 hours, SSDR froze and then closed. This has happened several times before but this time I opened the Administrative Report and took snapshots of the Alert and Errors. Perhaps this will help in finding a solution to the problem. I'm using Flex 6300, Win 7 Home Premium, SSDR 1.3.8
Roy,
Certainly a guess on my part but the first thing I'd do is reload Framework64. Looks like a NET.dll file failed.
Kirk, K6KAR
You cannot reload .NET to fix it. Microsoft integrated it into the operating system. Fixing a .NET installation is possible, but not for the faint of heart.1
Well then, maybe reloading the operating system is the answer IF the problem is within the OS
Running SFC /scannow will check for corrupted files and replace any that are found, including .Net files. It's easy to do, no need for brown trousers either.
While I doubt that .NET is the cause of the the SSDR crash, Microsoft provides a tool to fix common problems with .NET installations:
http://www.microsoft.com/en-us/download/details.aspx?id=30135
Good luck and 73,
Larry KB1VFU
Thanks everyone for your comments. I'll investigate the problem further and see if I can find a solution. I'll leave a comment should I find one.0
I believe I may have found a solution to not only my SSDR Stops Running but to Cat and Dax dropouts as well -- Please see "BSoD Caused by Microsoft Update".0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
