how to complie flexlib_api into dll
Roger Sjölin
I am a visual basic expres 2013 user and can not figure out how to compile the Flexlib_API into a dll in visual studio 2013 C# compiler. I am to lazy for learning a new programming language so please give me a hint.
/SA0AND Roger
/SA0AND Roger
I have a small sample project that will show how to use API using Visual Basic 2013 if that would help.
Dave W0DHB1 -
Load the project file for Flexlib in C# then Build the project just as you would a vb project. Once you do that, in your new VB project ,select Project, Add Reference. In the File menu that opens, navigate to the folder that contains the Flexlib C# project. Find the Flexlib.dll file in one of the C# project's sub folders. ( I'm on the road so this from memory... YMMV!) Once you select the dll file, click OK or add file(not sure which) you can use the "IMPORTS" feature at the top of your project. Then you can use the library. Good luck.0
Dave, I would be interested in seeing your code if you wish to share it. (unless, you've already shared it with me. I am not sure if you have or not) My email address is good on qrz.com WD5GWY James Thanks0
Ok, I have now managed to compile the FlexLib_API into dll.
/Roger SA0AND2 -
Dave
I would be very happy if You will send me a copy of Your Visual basic example.
rogersjolin@gmaiil.com
/Roger SA0AND
Dave: I am just starting up the learning curve - would greatly appreciate a copy of your sample project. Many thanks! 73, Tom K1FR, tm.stuff@verizon.net
Hi,
My name is Emily, a while back I started to get this message about geocalcpbw-dll download, I found geocalcpbw-dll on the web but it is confusing what to do next,
Can someone help for covering the problem?
follow the link https://pcpatchedup.com/geocalcpbw-dll
Best Regards,
(Emily Lee)-1
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
