Memories and Most Recently Used Frequency Utility
I am finding that when I make a memory when noise reduction is on and return to it later reduction noise is off. Any thoughts on this. Alan0
I will investigate this week. All FRStack support is handled through the support email link in the FRStack application. Please email me at MKCMSoftware AT gmail.com so I can contact you if necessary.
MarkPS. I have updated FRStack to address this issue. Version 0.5.4.0 public Beta release of utility is available. If your PC is connected to the internet FRStack will prompt you to install the new version. If not you can use the original link above to get the latest installer.
I believe they have, memories will be in release 1.4 which will be out in about one month.0
Version 0.5.5.0 public Beta release of utility is available. If your PC is connected to the internet FRStack will prompt you to install the new version. If not you can use the original link above to get the latest installer.
This version adds:
Favorites Tab and ability to mark Memory as a Favorite
TX Profile Tab and ability to link Memory to a TX Profile
Option to change button Font Size and Color
Import File now merges with existing memories
Replace horizontal button scrolling with wrapping
73, Mark AA3RK1 -
NICE update . . . Thanks
I like the new 0.5.5.0 release. Adding TX profile buttons is slick, and I like being able to adjust color and font of the buttons. Thanks!0
Good just keeps getting better. Ok wish list. I can now size it down to two Collins. You can go to one but the buttons stay at two wide but the tabs stack on each other. Can we get it to size to the tool bar like the woodbox meter. People think it is part of smart sdr until I shut smart sdr down. Love being able to set colors starting to feel like powersdr! Great job thank you for your work.0
I am unashamedly repeating the above comments - it's a great utility and if only it could be incorporated into SSDR life would be so much easier. It is gratifying to find others (infinitely wiser than me!) taking the time to write such a useful utility and having the generosity to share it with the rest of us.
The only problem I have now is that of screen real estate - even with 2 x 24" monitors I have so much information to display. All the more reason to incorporate these features into the next release of SSDR?
Jeff - G4IUA0 -
YOU ARE THE MAN!0
Mark, GREAT PROGRAM! THANK YOU!0
Mark, fantastic job on this software. Works great.0
Maybe Flix should have a central repository, for user uploaded programs, instead of haveing each user hosting at a different site. Tim - any issue with that??
Nice job Mark.
Mark and Group,
For some reason my "Avast" security determined there was a threat with FRStack and removed the file? I disabled the file portion of the security and downloaded again fine but when I enabled my security complete it moved the application out again, any help would be much appreciated as this one has me scratching my head. Evidently my security had an update and decided FRStack had an issue.
Thanks and 73's
Joe - WD5Y
Mark, many thanks for a most useful utility.
Merry Christmas and Happy New Year.
You will most likely have to add an exclusion for the FRStack.exe file. I am not an Avast user so I can not publish the exact steps to accomplish this task.
Mark, I tried that but could not get to work. Believe it or not I did an avast update and it solved the problem; an update to solve an update issue. Thanks for help, 73's Joe WD5Y0
Memories and Most Recently Used Frequency Utility supports SmartSDR 1.4
Version 1.4.2.0 AddsRadio Memory List - Create, Apply and Delete Radio Memories
Memory Mini Window - reduced screen footprint
V 0.5.5.0 release of utility
Remember window position and state
Support for frequency outside US Bands
Swap Slice settings with another slice.
Tracks most recently used (MRU) Slice settings for easy recall and storage to memory.
Save Slice settings to a Band Memory.
Mark, thank you for your program. It reads all memories I have
stored in my 6500.
What puzzles me, though, is that although the memories are
read by FRStack and populate it's memory window, if I click
"Apply" only mode change is applied, no frequency change.
Otherwise FRStack is great and I would like to use it for
memory management.0 -
We are considering doing something like this in the future.1
I can not duplicate this issue, please note:
The link up top works with the latest version of the program works with SmartSDR / FlexAPI 1.4.
https://onedrive.live.com/download?resid=D6EA27C831DD8A7A!914&authkey=!AOBrxzxCvgXMTYw&ithint=file%2cexe
If you are running version 1.3.8 use this version
https://onedrive.live.com/download?resid=D6EA27C831DD8A7A!1187&authkey=!ADsEnroCrCQ2IyE&ithi...
If this is not your issue, please contact me via the support link in FRStack Help menu.
73, Mark AA3RK0 -
Ok, Mark, I just sent you a support mail.
Thanks for answering and 73, Alex DH2ID0 -
FRStack 1.4.3 has been released. If you already have FRStack installed you will be prompted to download the new version. If not the link at the top will download the latest version.
This version add new features:
Create global hotkeys to invoke MOX, TUNE, ATU, MUTE, Volume, NB, NR, ANF.
Radio menu has new features- Enable Hotkeys
Hotkey Editor
Enable TX on slice set
Slice set always enables TX
Follow radio active slice
Slice set mutes other slice
Radio slice active mutes inactive slices
New Slice panel background context menu
Lineout Mute
Headphone Mute
Binaural RX
Monitor TX
New Memory button context menu items
TX Enabled
Mute Enabled
3 -
This is my goto program for scanning the bands..Cant live without it
-jim NM1W0 -
Thank you for FR Stack - as someone else commented, it would be a very nice addition to Smart SDR.
Tim0 -
Bruce - N5FD
great response from the community!
I did not post the comment about Flex Radio not acknowledging the contribution, w
Wires crossed I Suppose. I think i'M the only N5FD; I'm pretty sure, my ticket confirmes it!
I love this program and use it all the time. Not to sound unappreciative but I'd really like to see a scan function. In other words, have frequencies stored in a couple banks and have the ability to scan through the frequencies in each bank and stop when squelch is broken. I have several VHF frequencies I use and it would be nice not to have to use up a bunch of slices to monitor them. One slice that scans through a bank of frequencies would be wonderful.
Are there any plans for such an addition?0 -
I will look into adding a Scan Bank(s) feature to FRStack. If you would like to provide additional input on how this feature should work please email me at
aa3rk AT arrl DOT net
73, Mark0 -
Thanks Mark. I'm trying to put something together right now.
I’ve already sung the praises of FRStack, but Mark (AA3RK) has clearly had his ear to the ground and the latest beta version offers even more features, including a scanning function as well as addressing other shortcomings in SSDR such as user definable hotkeys.
I hope this additional functionality is eventually incorporated into future releases of SSDR, rather than having to run additional standalone apps.
Mark offers excellent support, and tonight kindly remotely accessed my computer to remove an obscure gremlin causing FRStack to not load properly. It is gratifying to receive such help from a fellow amateur, remembering all the time and effort freely given into authoring the program in the first place.
Jeff - G4IUA
Jeff - I couldnt agree more about the support, attention to detail, and listening to the users that Mark did in the beta. He has set the bar very high.
But I MUST disagree about having this incorporated into smart sdr.
If its in smart sdr it wont get the level of attention to detail and care that it deserves. I'd much rather have smartsdr be a core enabler, and see things like memory, DAX and CAT all be done outside of Flex such that it could get more attention. Have Flex give us great APIs and let others build the ancillary tools.
2
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 933 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
