what updates would you like to see in powerSDR
John
Many of us would like to see updated / fixed in the powerSDR software, so why not list them here for the guys at Flex to see. Hint hint !
well here goes nothing. I would like to see a fix to the TNF where the width of the filter shrinks in size, when moving in around within the passband. Its very irritating to say the least. Ice is now broken so fire away at will.
Improved CWX function where it is less likely to lock up PowerSDR if you click on different macros too quickly .More marcros .0
more TNF filters and perhaps some blocks of ten made available for those broadband qrm signals
On the 5Mhz band, one can transmit outside the designated frequency boundaries. This needs to be fixed as per the mode used.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
