Flex3000 using iMac
Jim G3YLA
Hi Flexers, I have been a happy Flex 3000 user for about 3 yrs (mainly CW) and now have access to a high spec iMac. Anybody used a Flex 3000 with one, and are there any Firewire/USB3/Thunderbolt issues here? If it is possible in bootcamp, which version of windows (7 or 8.1) have you used or prefer? Mni tks es 73 de Jim g3yla
Hi Jim,
I don't have an answer to your question but have one for you considering your experience with CW with the FLEX. Just getting into using the FLEX for CW and I have a Bencher chrome keyer. I am finding that, sometimes, the radio will hang up, or briefly suspend, on dah's with the keyer. When it does this I tap the keyer and it releases. Given your experience using CW with the radio, would you have a recommendation for what settings or adjustments on the radio or key would solve this problem. I have already tried a few variations but can't seem to find the solution.
73's
Mark
WA2DIY0 -
Hi Jim,
I have a MacBook Pro. I have been using. First with the 3000 and now with my 6500. It works just fine. I use 8.1 Pro in boot camp. 8.1 is great. It is fast clean code and works very well however, I set it up to bypass the lock screen at boot up and go strait to the sign in screen, then desktop. Windoze 8 is the version they tried to force everyone into the touch interface. I prefer it to 7 because I like the keyboard shortcuts, one drive integration and how fast it is.
73, Dan KM6CQ0 -
Hi Jim,
I had a Flex 3000 that I used very successfully with my IMac (27", 3.5 GHz) running bootcamp. I first used Windows 7 and then upgraded to Windows 8.1. Both worked equally well. I bought an Apple Thunderbolt to Firewire (800) adaptor. I then bought a Firewire 800 to 400 adaptor which is the version of firewire that the 3000 needs. It all worked well together.
http://www.amazon.com/Apple-Thunderbolt-to-FireWire-Adapter/dp/B008RXYOKY
http://www.amazon.com/NewerTech-9-pin-FW800-connector-adapter/dp/B002OVJ83I/ref=sr_1_cc_2?s=aps&...
Let me know if there is anything in specific that you have questions about.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
