SSDR CAT gone nuts
William Hein
I have 8 physical serial ports on my computer. Also, I am using a USB 2.0 port assigned to COM 16 to connect to AlfaSpid rotator controller via USB. Flex Control is assigned to COM 40. So, COM 16 and COM 40 are the Foreign Virtual Ports.
SSDR CAT has gone wobbly today. I normally have a Flex virtual serial port Shared pair COM 9-19 and I connect logging programs to COM 9 without any problems - usually, but its now suddently broken.
COM 9-19 pair has disappeared from SSDR CAT Available Flex Serial Ports even though COM 9 still appears in "Connect 3rd Party Program To Port" and COM9 appears on the Port Map.
N1MM Logger+, which had been working OK, will not connect to COM9. If I set up a second Shared Flex Port at COM 10-20, Logger+ won't connect to iCOM10, either.
No amount of Delete All Virtual Ports and rebooting and setting up new ports fixes the problem.
Suggestions?
Suggestions?
I meant dedicated ports above, not shared0
I decided to try this one last time:
deleted all the Virtual Ports
power cycled Flex 6700
rebooted computer
created new COM 10-20 PPT DTS/RTS pair in SSDR CAT
connected N1MM Logger to COM9 (CAT) and COM10 (PTT)
seems to be working now, no idea why N1MM wouldn't connect to COM9 for last hour.
I didn't mention it before, but I was getting frequent "Can't create new port, please quite SSDR CAT" (I'm paraphrasing) while trying to fix this.
Fingers crossed
Bill AA7XT
I am trying to remember if COM9-19 every should have appeared in the Available Virtual Ports list?0
William I have had this exact problem in the past. The only way i could fix it was to uninstall all my Flex software 3 programs then re-install it. If Cat was a stand alone install it would be easier but it's not. I worked for a few days trying to resolve it until I finally removed and re-installed and all was fixed. Sorry Ian0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
