I am looking for a reliable way to connect CW Skimmer to DAX I/Q
edited November 2018 in SmartSDR for Windows
I have been using CW Skimmer with SSDR / Flex 6700 on and off for a while. However, mostly 'off' as the connection is flaky at best. Sometimes I can't get it going at all, other times it works fine. I don't know why.
I downloaded SDR-Bridge but it seems to be made for Skimmer Service not plain vanilla CW Skimmer. Nice looking program, thought.
Here's my set-up:
Latest versions of SSDR, SSDR CAT, DDUtil, and CW Skimmer.
i7 PC with Win 7 64 bit and 8 GB RAM.
here is my set up, note that CWS is not getting the right SSDR frequency (yes, I have changed frequency in Slice A to 'wake up' programs connected to it) via DDUtil and DAX I/Q 1
Welcome!
  • Member ✭✭
    edited April 2017
    Some time help to start CWskimmer separately and after by DDutil, i have very equal setup without visible problems:
  • Member ✭✭
    I will try starting CW Skimmer after DDUtil. Thanks for the tip. Right now DDUtil is set up to launch CWS on my system
  • Member ✭✭✭
    edited December 2017
    Bill,  SDR Bridge seems to work the best here for just plaibn Skimmer to Flex interface.  It will also work with the Skimmer Aggregator to send spots to the RBN but its not necessary to use it for that purpose.
  • Member ✭✭
    Larry -- how do you connect SDR Bridge to CW Skimmer? I can't find any instructions for this.
    Tnx
    Bill AA7XT
  • Member ✭✭✭
    edited December 2016
    Bill send along ur telephone # and I'll walk you through my set up.   k1uo (at) arrl.net is ok
  • Member ✭✭
    I have got SDR-Bridge working with CWS and SSDR now. Will give this a go.
    Bill AA7XT
  • Member ✭✭
    edited April 2016
    This combination works like a charm for me.  Before SDR-Bridge, I spent many frustrating hours.
    73, Bill, N5TU
  • Member ✭✭
    edited July 2015
    Thanks for kind offer, Larry, but I got it worked out and CWS working great now with SDR-Bridge
    Bill
