Can we work full-duplex (Satellite mode) with DEMO LDPA on 2mtr and a 70cm/10m Tranverter?
Is it or will it be possible?
I have just ordered the 432/28 transverter from DEMI. As soon as it arives I will try. I have already the 2m LPDA in use. My first attemps with transmitting low power at 28 Mhz on ANT1 and at the same time receiving om 144 MHz on XVTR showed a normal panadaptor display for 144 Mhz but the sound output was internal muted.
How do you plan on using the XVTR port for both units? Or do you plan on using the 100W transmitter (Turned down) as the driver?0
The XVTR can only be used for just one band at the same time, Or as a transmitter or as a receiver. So We have to use the turned down an attenuated 100W output for transmitting. Or always use the XVTR for transmitting and receive on 28-30 MHz band. This is the most save way of working I think.
What is Your intension ? TX on 144 and RX on 432 , the other way around , or should both situations be possible ? As soon I have my 432/28 transverter , we ( pa0wmr and me ) wanted to start experimenting full duplex , cross band EME communication.
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
