PTT using DEMI 2MTR XVTR
Steve/N6KOG
Unable to get the DEMI two meter transverter to transmit, using any one off the three "TX Relay outputs" RCA connectors #1, #2 or #3 for the PTT line on the FLEX-6500. While the radio is set to XVTR on 2 meters. Receive is working OK. Upon switching back to any HF band the three "TX Relay Outputs" will key up the HF amplifier and the 2 meter XVTR. This problem may have already been reported?
i have the same problem with the demi amp. you can disable the ptt relay but when i move bands the relay enables itself.
any idesa?0 -
I am using transverters with Flex 6500 and I suffer the same problem. Three PTT outputs and no one is XTVR dedicated. I have to deactivate them manually when I am working in HF. Fortunately I am not fond to PAs. Please Flex gurus, do something for us. Leave one of the three PTT otuputs activated only when XTVR bands are selected.
Luis EA3OG1 -
This feature request is on the "to do list".1
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
