Is the Flex 6300 able to transmit on the 5MHz NoV frequency allocation in the UK.
  • GI4FZD
    GI4FZD Member
    edited April 2017
    yes
  • DrTeeth
    DrTeeth Member ✭✭
    edited December 2018
    Yes, but be careful as it also transmits outside it too. I do not know where the programmed band limits are.
    Originally, when I reserved mine (ML&S), I was told that I could have the conversion on request and I would have to show my NoV. When I actually purchased a few weeks later, I was told that they were all sold 5MHz capable.
  • Bob - G3WKW
    Bob - G3WKW Member ✭✭
    But it won't do WSPR because the frequencies are too close to a sub band edge and it won't allow the carrier frequency to be set in the right place for the 1500 Hz tones generated by the software.
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    Hi Bob,
    Do you know where the TX boundaries are? I managed (only once, hi hi) to Tx outside the 1000Hz JT65 area by about 1.5-2KHz.
    I'll send an email to ML&S (I got my 6300 from them) to see if they can supply the info.
    Later:- Email sent - will report back. AIUI, ML&S generate the necessary config file so different retailers may have different setups.
  • Steve Walker
    Steve Walker Member
    edited September 2016
    The Flex band plan for the UK is er UK centric and contains the limits on 5Mhz as allowed by the band-plan - you can generate a CW carrier to each band edge as the RSGB show here http://rsgb.org/main/operating/band-plans/hf/5mhz/
    I had the US allocation in my 6300 when it arrived and ML&S eventually sent me the UK one; however FRS has already sorted me out with the correct regional file.
    So yes, Dolan it works fine in the UK.
    73 Steve
  • Stewart, GM0GTU
    edited May 2015
    I had to run the TURF file to re-install the 60 Metre band and the other UK band allocations after doing a factory re-set. It would be great if the UK 60 Metre allocations were displayed in SMARTSDR as they are in POWER SDR.
