Wireshark suggested filters
IW7DMH, Enzo
Hello,
I am trying to sniff the TPC/IP packet from/to Flex and PC and I am using Wireshark.
Can you suggest some kind of filters I should use to display only data packets used in the command protocol? I would like to get something like this:
from PC to Radio: request ****
from radio to PC: answer yyy
Reading data packets in wireshark is like filling a glass of water in Niagara Falls
HI
73' Enzo
iw7dmh
73' Enzo
iw7dmh
Hi Enzo,
I don't know what ports SmartSDR uses, but you can build a WireShark filter to only show traffic to or from a specific IP address:
host 192.168.0.99
Replace the IP address in that example with the specific address of your radio, and that should help filter the traffic.
Best 73,
Jim N7CXI
Hello Jim,
filtering using only IP address is not enought as traffic between PC and Flex is really very high.
For "Discovering protocol" you have to filter UDP packets on port 4992 and for "Command Protocol" you have to filter TCP/IP packets on port 4991.
Also with these additional filters I still get a lot of packets so a more specific filter would help me in following traffic.
I'm not very used to study protocols. This should be a children's game for some Ciscoman friends.
Thank you very much.
73' Enzo
iw7dmh
If you're filtering everything except the Flex protocol packets, I'm not sure what else you can filter?
The 6000-series radios move a lot of data over the ethernet connection, so there will be a lot of packets.
Jim N7CXI
Yes, there will be again a lot of data.
What I am looking for is ignoring all PING packets and filtering packets by "data" content: for example only packets that contain a string like " |cw " and so on.
It seems Whireshark has a very complex filtering syntax. I have to search better.
73',
Enzo0 -
Here we are.
After some attempts I setted up two kind of filters: one for discovering protocol and one for command protocol. You have to type the following strings in Wireshark filter textbox
Discovering Protocol
udp.port==4992 and ip.src==169.254.8.146
Command Protocol
tcp.port==4992 and ip.dst==169.254.8.146 and tcp.len>0 and data.data contains "cw".
I made an attempt to change the keyer speed from 18 wpm to 17 wpm.
here is the packet sent from PC to Flex
And here the answer from Flex to PC. It seems answer is send twice.
For other commands you can change your filter from "cw" to which one you want.
Hope this can help.
73' Enzo
iw7dmh
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
