audio
Keith Morrison
been messing around with my Audio settings and was wondering if the Flex-3000 has a mic compression / processor button?? or do I just need to mess around with the 10 band equaliser settings
cheers Keith
2
you use the CPDR slider or the DX slider, run the DX slider around 2 or the CPDR at 2 also. This works something like compression. If you like we can meet on 40M on7.59.000. I can help with this. I am on a 3000 as well
VA3WTB Bill
and mess around with CPDR and DX sliders.0
cheers fellas, will have a mess around tomorrow, thanks for the offer of a sked Bill but it's 1235AM here in the UK and the XYL would not be impressed if I woke the house up LOL
Keith
Yes, Keith, as others have said, the 300 has two different "flavors" of compression. The CPDR is a mild compressor that ads more talk power and keeps your levels stead without adding too much "edge." Depending on your other audio settings, you can often run it anywhere from a 2-6 with not much problem. The DX button is more "edgy" and adds even more punch and some highs. I wouldn't recommend running it more than about a 3 or 4.
There is an excellent document on the FLEX support sight by W1AEX that details how to adjust all of the various audio settings in the audio chain. There are about 8 of them and you can introduce distortion and problems at any level if you are not careful. But once you get things set up the 3000 can can sound really, really nice. You can create multiple Transmit "Profiles" for different settings - DX, Rag Chew, ESSB, etc.,
W1AEX also has an excellent tutorial video on YouTube if you are a more visual learner.
YES you will need to spend some time adjusting your TX EQ 10 band Equalizer. This is one of the keys to great audio. Never trust a mike and rig on their own. A poorly adjusted rig can make an expensive mike sound like trash, but a well EQ'ed rig can make an average mike sound good, up to a limit. You can't add what isn't there in the first place. But you can help things out a lot with EQ and a little compression.
Good luck,
Ken - NM9P
This is the link to the W1AEX article Ken references
http://helpdesk.flexradio.com/hc/en-us/articles/202118248-TX-Audio-Setup-Procedure-by-W1AEX-Rob
Thanks, Tim. Here is the Youtube of the process, too.
https://www.youtube.com/watch?v=fV_iolSf3OA
Here is another, more lengthy one by G7CNF that covers a few other adjustments.
https://www.youtube.com/watch?v=2trJjUObLkY
Ken - NM9P
Thanks to you guy's I now have ear piercing DX busting audio
73 Keith M1VHT
So much for smoothness,,,lol cheers1
Don't worry Bill I also set up a smooth rag chew audio too!
73 Keith M1VHT
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
