RTTY ,split more 10khz with DW780, DAX, flex 6300
on5po
on5po Member ✭✭
edited November 2017 in FLEX-6000 Signature Series
Photo of on5po
on5po
  • 23 Posts
  •  0 Likes
hello,  who could help me how to open the second chanel of the DAX
I only have dax chanel 1 open
to be able to make the split in rtty of more than 10Khz
I have win7,64 bits, flex 6300, and DM780
so possible with photos
thank you for advance
on5po@hotmail.fr
on5po, Janny
  • Al K0VM
    Al K0VM Member ✭✭✭
    Janny,
      Running rtty split with two DAX channels requires that you use two slices..used DAX 1 on slice A and DAX 2 on slice B.  In your RTTY program, select DAX1 RX for receive ( caputre ) and DAX 2 TX for transmit ( playback).  You should see appropriate  displays in the the DAX control panel. with DAX 1 enabled for RX and DAX 2 enabled for TX.
    AL, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    Thank you Al,  my problem, I only have a chanel the 1
    I don't know how to make to have the chanel 2
    the chanel 2 doesn't function in TX
    janny, on5po
  • Al K0VM
    Al K0VM Member ✭✭✭
    Janny,
      How many channels show up in the DAX control panel? Can DAX 2 be enabled for TX?  If you go the  windows control panel>manager audio devices, do any DAX 2 channels show up there ??  ( you may have to enable' show disabled devices' )
      You may have to uninstall and reinstall DAX.
      In your RTTY program, do other DAX channels show but DAX 2 is missing ?  There is nothing magic about DAX 2 if another one is available.. Some RTTY programs can not display all the DAX channels that are installed.
    AL, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    AL,
    In the DAX, chanel 1 and chanel 2 I have RX  in dm780 waterfall  in chanel 1 TX... ok
    chanel 2 TX no... no power ptt of dm780 toward flex.... why?
    I don't know or go have ptt to the chanel 2
    veils or is my problemimageimage
    Janny,on5po
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al,
      rectification not of RX and TX with chanel 2
    only chanel 1
    sorry
    my problem is to know or go activate the chanel 2 in RX and TX
    Janny
  • Al K0VM
    Al K0VM Member ✭✭✭
    Janny,
       What DAX TX devices show up in the Windows Audio Device Manager ? Do They show up in your RTTY program ?
    AL, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al,
      I have 8 X DAX (only) reserved audio TX
    how to make to have DX audio TX
    it is my problem I am not very strong to compute of it, sorry,
    Janny
  • Al K0VM
    Al K0VM Member ✭✭✭
    Janny,
      Does your DM780 Soundcard transmit selection look anything like this ?
      Please attach a picture.
    AL, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al,  I have modify in DM780, as asked, to see capture
    chanel 1 RX.. ok, chanel 2 no tx imageimageimage
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al   I only have the TX with chanel 1 and DAX audio TX1(DAX TX Audio)
    in DM780, Soundcard, with DAX Audio TX2(DAX TX Audio).... TX no
    Janny
  • Al K0VM
    Al K0VM Member ✭✭✭
    That looks okay..  Since you are showing signals in the Windows Audio Control panel for Reserved TX2, that means that signals are being presented to the radio.  See attached..image
    Note:: In lower right corner.. High cutoff must be above tone frequencies.
    Note DAX button must be enabled in the P/CW panel.
    Note: During transmit,the level meter indicates signal.
    Your close..
    AL, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al,
     With tune--> OK --> indicate signal
    Chanel 2 B in, with send or macro of dm780--> below TX lit no power,, DAX--> lights --> no indicate signal
    Janny
  • on5po
    on5po Member ✭✭
    edited January 2017
    Al,
      now it is OK, I had forgotten to light the chanel 2 and TX  in DAX control panel
    you are  the best
    thank you for your patience
    the only problem, when I want to use with the TX A,  must change in soundcard dm780 to come back has DAX audio TX 1  for split........ I must work with DAX audio TX2
    does have every time to change?????it is normal
    ON5PO, Janny
