Flex-3000 and DM-780 (no TX)
Hi all, I cannot get my flex 3000 to go into TX when using DM780 it receives & decodes fine but won't go into TX.
my set up is DDUtil V3. VSP manager and VAC 4. everything is connected even the radio in DM780 is connected. i get the following message when closing down DDUtil.....object reference not set to an instance of an object at DDutil_V3.setup.processDSPfilters0
any help would be good thanks
Keith M1VHT
right folks the plot thickens, I still have the problem described as above, however when I use the full blown HRD programme & DM780 with in it I can both RX & TX with no problems I have the full blown HRD set up exactly as I have in when I am using DDUtil com ports, VAC & PTT the same too.
yet it won't TX when using the DDUtil programme, I just can't understand it.
for the time being I will use the full blown HRD but seems a bit of a waste to have 2 radio Payne's going at the same time using valuable resources CPU etc etc.
thanks Keith
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
