My Equalizer can't be onTx and Rx at hte same time Any news on FSK?
Len
If I have my Equalizer on RX then it doesn't work on TX does anyone else have this problem its a 6500 Also any news on FSK
That sounds odd. Make sure you activate TXEQ and click the ON button. But remember that when you click the RXEQ button, the TX light goes off, not because it is not working, but because that is the indicator that lets you know whether the EQ sliders you are adjusting are for RX or TX....
If the ON button is lit up when you press TX EQ then it should be working.0 -
Thanks I'll give it a try Maybe I just misunder stood it I thought both lights had to be on
Len
The RX and TX buttons light up to tell you whether you are adjusting the sliders and activating the RX or TX EQ function. This will be more clear when you have the sliders adjusted differently for TX and RX. They jump to the current setting of each mode when you press the appropriate button. The ON button also lights (or turns off) to indicate whether the function is active or not when you have selected either RX or TX.
Play around a bit and you will get it. The neat thing about SDR's is that it is really hard to "break" them. If you get it really **** up... just reset the whole thing and start over! hi hi.
Ken - NM9P0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
