Echo when using Skype for remote audio
WG0C
WG0C Member
I found if the "default device" and default communication device" are both selected on the same playback, a bad echo is heard. Select another device and then make it the "default device" to get rid of the echo. The DAX audio Tx 1 is the "default communications device".
Perhaps there is a better way to configure this. If anyone has ideas, I'm all ears.
Don WG0C
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    You don't want you Windows Default devices set to DAX at all..  Set your Skype to the DAX input /output  .  Move you default devices back to the computer sound subsystem ..
    Dudley
