How to setup FreeDV with the 6300...????
The Count
Downloaded the lastest FreeDV program and got it to at least display the waterfall put not really sure how to set it up for properly with the 6300 and all the DAX options...Any help is appreciated until FreeDV is included in the upcoming new SmartSDR release.
Peter
Peter
I deleted my copy of FreeDV. I figure I can wait another month to try digital audio.
Thanks for absolutely zero help!
For the FreeDV receive input, use a DAX RX line. For FreeDV receive output, sent the audio to your computer's sound card. For FreeDV Mike input, you need to have a mike or USB Mike connected to your computer and select that computer line . Then send the FreeDV transmit OUT to the DAX TX audio line on the same channel that you are using for RX. The enable DAX on the Flea transmit panel. That should get you started. Then see the directions for other settings. Hope this helps.0
Thanks for that info. I basically got things to work but the quality was pretty bad in both directions, probably because I am not even running the Flex under real Windows but Parallels. So 2 sets of audio adjustmets to get just right. But I think its just a matter of weeks for the SmartSDR update that will include the FreeDV so that will be much better.
UPDATE: Managed to get 90% copy on a QSO on 14.236. Appears I did not tune that red line properly in the waterfall windows before.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
