Ed, I believe that you are thinking about VB-Cable,
Doug
VB-Cable it is donationware and available in 32 and 64bit configuration for Windows op system. Downloadable on the internet at http://vb-audio.pagesperso-orange.fr/Cable/index.htm.
I am using the 64bit and using both the A and B versions to get both TX and RX audio paths for my flex3000.
Hope this helps.
Doug K4DMH
Hope this helps.
Doug K4DMH
Doug,
Thank you very much for the info! VB-Cable does sound familiar. I will give it a try this afternoon if I can put away my 6700 toy for an hour or so.
Ed, K0KC
Doug,
I uninstalled VAC 4.14 and installed VB-Cable and it seems like my DT problem is solved! I need to let it run for a few hours to be sure. The 6700 is turned off now and I will operate with the 5000 for the rest of the day.
Thanks!
Ed, K0KC
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
