Getting started question
IW7DMH, Enzo
Hello,
while I am waiting for my new Flex 6300, I am taking a look at the latest FlexRadio API archive (FlexLib_v1.3.9).
I am finding it a bit hard bearing among lots objects in the various projects and therefore I would ask if it is possible to have some help for this simple use case:
- Acquiring radio control (I suppose it is like getting a radio instance)
- Reading the VFO frequency
- Set the volume level
I don't want to use the cat approach but the powerful api access instead. I can't find the documentation for all these classes, nor a class diagram that can help me. I would be glad also for a code snippet.
Thank you very much
73' Enzo
iw7dmh
Thank you very much
73' Enzo
iw7dmh
Enzo. Your translator is broken. I have no idea what you just asked.0
I am talking about writing a simple Windows application that can interact with a Flex Signature radio.
Surely my translation is not perfect, but most of the terms I used, are well known to software developers.
Best regards
I thought his request was perfectly understandable both times
He just wants better documentation of the API so he can find the classes that contain control for the radio's volume and frequency as well as a copy of some sample code so that he can see how to write the application to bypass using CAT in order to address the radio directly..
3 -
Well of course! Why am I not surprised?0
Yes, that was what I meant.
In the meantime I found this interesting post https://community.flexradio.com/flexradio/topics/first_steps_with_flexlib
with an answer by Eric:)
I'll start from here.
Thank you very much
73 '
iw7dmh
Hello,
I am back after doing some tests, but with no great results.
I followed the directions of Eric and tried to write a simple program.
When my program starts I get the error listed below, and any radio is found.
A first chance exception of type 'System.Net.Sockets.SocketException' occurred in System.dll
The socket error happens when SmartSDRCat is already running, otherwise no errors but again any radio is found.
Also SmartSdrCAT, compiled from FlexLib 1.3.9 source, can't find any radio, while the version getted from the installation package (luckly) works fine.
I really do not understand where I'm wrong.
Here is my simple source code and I would be glad for any help.
73' Enzo
iw7dmh
using Flex.Smoothlake.FlexLib;
using AsyncSocketsV2;
using log4net;
namespace FlexTest
public partial class Form1 : Form
Radio this_radio;
public Form1()
InitializeComponent();
API.RadioAdded += new API.RadioAddedEventHandler(API_RadioAdded);
API.RadioRemoved += new API.RadioRemovedEventHandler(API_RadioRemoved);
API.ProgramName = "FlexTEST";
API.Init();
* API_RadioAdded
void API_RadioAdded(Radio radio)
Console.WriteLine("API_RadioAdded Fired: " + radio.ToString());
this_radio = radio;
* API_RadioRemoved
void API_RadioRemoved(Radio radio)
Console.WriteLine("API_RadioRemovfed Fired: " + radio.ToString());
this_radio = null;
private void button1_Click(object sender, EventArgs e)
Close();
Well, it was really hard, but in the end I solved the mystery.
The code in the previous post, even if so simple, is correct and works well.
The problem is related to the Windows firewall settings !!!
When you run the program for the first time, Windows firewall prompt you to allow your application connections. Even if you agree, it actually doesn't happen. YOU HAVE TO CHECK ALSO "Public Network".
If you forgot it, as you can see from the image below, you wil have two connections still blocked (they have the red icon).
These are just the TCP and UDP rules used by Flex Library to communicate with your radio.
You only need to change (allow connection) these two rules and the program magically works.
Hope this can help other beginners like me.
73' Enzo
iw7dmh0
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 809 Peripherals & Station Integration
