Newbie question on waterfall view.
Adrian
Looks like u got lots of local noise and/or internal noise in ur station Suggest you read. My paper on how to build a quiet station https://www.dropbox.com/s/kffp92esffo3zy5/How to Build a Quiet Station V2.pdf?dl=01
Looks like really bad local RFI. So sorry! Hope it's relatively easy to track down.0
Adrian:
It is a diagonal trace because the source of your noise is drifting in frequency. We see that the noise floor to the right of your receive frequency is lower than the noise floor to the left.
If you set your receive mode to CW, SSB, and AM, respectively, do you hear anything? Sometimes the changing energy level that raises and lowers the noise floor does not create noise that the receiver hears. From the looks of the irregular trace it might sound like a buzz saw.
Your overall noise floor on 20 meters seems to be very high. I am accustomed to seeing -110 when near a city and even lower in a very quiet location. Your noise floor appears to vary in the mid -90's.
This is an opportunity to use your 6300 as a test instrument. If you widen the receiver as wide as it will go you will probably see a recurring pattern of rising and falling energy. Document the periodicity of the peaks. Many of use on the Community had a lot of cumulative experience in tracking down noise. KY6LA did an excellent job of documenting avoidance techniques. If you document the entire spectrum that your 6300 covers that will give us a chance to identify the likely culprits. It is a lot easier to search for a noise source if the emitter is narrowed down to one or a few likely sources.
Let us know what you see and hear and we'll try to assist further.
Reg
Thanks guys this is great info. the noise floor drops considerably in the morning before 1000h MT (-110db) I have attached another diagonal waterfall. Yes listening to it you definitely hear the “buzz saw” modulate as it tracks from a higher frequency to a lower one. Any ideas of what would cause this type of noise?The second image is the zoomed out view.
have downloaded your whitepaper and working through the noise reduction techniques.0 -
Looks like someone has a Plasma TV broadcasting noise...
One of the benefits of a broad spectrum radio like the 6000 series is that you see EVERYTHING on the air..
One of the issues of the 6000 Series ... is that you now can SEE EVERYTHING TOO... so "****" which did not bother you on a legacy radio albeit you heard it whipping out signals becomes a big bother because you can finally see how really bad it is...
Good luck hunting down the RFI...
We have some hockey puck under counter halogen lights that make traces like this when they are turned on. I ask my wife to unplug them whenever they are not absolutely needed.0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
