ALC problem on Flex-6500 SSDR 1.3 Exper 1k-FA
iz7auh
Member ✭✭✭
hello,
I'm doing tests with my FA Expert 1K using the new "Hardware ALC" but I notice a problem when in fact it is on my modulation appears to be at times, fragmented, and if I disable ALC settings manually FlexRadio and I reduce the power not I have no problem of modulation may depend on what?
thanks
IZ7AUH Frank
thanks
IZ7AUH Frank
For what reason you need ALC ? No need for a modern TRX and a modern SS PA. Forget using ALC !0
Whats is a good using of my Expert 1k with SSDR 1.3? Can you give me a guide?
Best 73 IZ7AUH
I do not use ALC with my Expert 2k-FA I use DDUTIL to automatically limit power by different bands to the Amp0
Frank Here is a screen shot of my auto drive settings for my expert 2K-FA.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
