Flex 6300 event log? Determine why unit shut off by itself
N2FA
N2FA Member ✭✭
Hi,
I'm a new flex user and I had an event that may be of concern. I was wondering if there was a log or event file I can look at.
I was monitoring a PSK31 conversation and the Flex 6300 shut off. It would not turn back on via the on button. I had to power cycle the power supply to get it to turn on.
When I fist setup the unit it refused to get an IP via DHCP. A power cycle fixed that.
I just want to make sure I don't have a bad unit or need a default reset.
  • N2FA
    N2FA Member ✭✭
    edited March 2018
    I found the power off issue was the power supply intermittently outputting low voltage. Just want to let anyone reading this know that there is no Flex issue here.
