Brighter Linework in Panadapter - for improved legibility
Color schemes have been mentioned before, and I think the concern is legibility more than just wanting to pick different colors. On my monitor the line work on the panadapter can be difficult to see clearly.
As an experiment, I created a snapshot and lightened the lines up. See the picture below.
The top is the original -- the bottom is with the lines lightened up a bit. For me this makes a big difference.
I'm not sure if others would agree but having some control over this would be nice. This is just another item that could be bundled under the topic of "UI enhancements" as noted in another post.
https://community.flexradio.com/flexradio/topics/idea_to_improve_the_swr_and_power_scale_readability
What do you think, is this a worthwhile change?
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
*** CLICK to enlarge ***
Regards, Al / NN4ZZ
3
Please also see the link below to the idea for Panadapter Fill. Making the frequency lines more visible as suggested above needs to be considered if the trace is filled.
One solution might be not to fill all the way to the bottom but leave the frequency lines exposed. Otherwise determining the frequency of a signal could actually be even more difficult.
Another option might be to display the frequency lines in a contrasting color to stand out from the fill.
https://community.flexradio.com/flexradio/topics/panadapter_display
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com1 -
Somewhere earlier (I was there was an easily searchable index) I proposed different colors for each slice for improved visibility and ease of differentiation0
Hi Howard,
Yes there are several requests for user selectable color schemes, I think yours was one of the first. I entered a few other GUI improvements also like this one above, the S-Meter improvement, the RF power scale improvement. And there are a number of others like the option for panadapter fill.
They are probably low priority for a lot of folks but for some of us, improved visibility and faster determination of the values is important. I doubt they will rise to the level needed to get on the road map but hopefully at least some of them are being considered.
Others who are also interested in these type of improvements can search for the ideas and CLICK the LIKE button at the top of each one to add their votes.
Regards, Al / NN4ZZ
Here are a few of the links to the color schemes ideas.....
https://community.flexradio.com/flexradio/topics/color_choices_for_background_and_meters
https://community.flexradio.com/flexradio/topics/color_code_slices
https://community.flexradio.com/flexradio/topics/how_about_digital_swr_meters_and_more_visible_color...
Regards, Al / NN4ZZ
Need this too
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
