Flex 6300 and WSPR Audio Problem
Jeff
I am running WSPR, Version 2.0 Rev 1714 and a Flex 6300. I have been able to configure the CAT in WSPR so it works with the 6300.
I am not able to get audio from DAX RX 1 to the WSPR program. When I select DAX RX 1 as the audio source for the input to WSPR and DAX TX Audio 1 as the output from WSPR, I get an invalid device error in WSPR for both. I am able to see audio on the DAX Control Panel on RX1. I have made DAX Channel 1 Audio active on the the receiver and DAX TX Audio active on the transmitter.
I am using Windows Professional 7. I have also tried disabling the other virtual DAX sound cards in windows but that didn't help. I have also assigned other sound cards sources as defaults so windows doesn't capture the DAX sound cards for other programs.
I have also tried using WSPR-x but the WSPR-x program crashes when I select options.
The only alternative I am seeing at this point is to use an external usb sound card, the audio output on the back of the 6300 and routing transmit audio from an external usb sound card to the transmitter through the DB 15 HD connector on the back of the 6300.
Does anyone have any better ideas or have you been successful in making this work?
Jeff
KD6RC
Jeff
KD6RC
I just use VOX control and dax rx1 and tx1 with wspr 2 and it works fine, no problem. in Windows 7 Best of luck Rob0
Just an idea; are the sample rates the same between DAX and what WSPR expects?0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
