No audio for DAX?
N2FA
N2FA Member
edited September 2018 in SmartSDR for Windows
From what I gather there is no audio on the PC being streamed by the 6300. This is a future upgrade. I thought I may be able to get the audio off of DAX but for the life of me I cannot get audio to even show up via DAX. I followed the Flex Youtube tutorial but still nothing. No audio shows up in the audio control panel under playback nor the DAX control panel. I see all of the DAX input and output devices but there is no activity. I know it hard to see what I have done so far but any help would be appreciated.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    It would help to have some screen shots of your setup By PC being streamed? Do you mean a second PC operating remotely ? If so, what streaming program are u using?
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    If you are tuned in to a SSB signal and you have the DAX selected to a number, you should see a red audio line follow the syllabics of the audio on the DAX window. Many times when I bring up the DAX I see no red audio line. To correct this problem, I close out the DAX and manually re-instate the DAX program. I find it helpful to put a DAX icon on the screen so I can conveniently bring it up.
  • N2FA
    N2FA Member
    edited March 2018
    Hi,
    No sorry I mean audio out of Smart SDR. I guess it is considered remote since it is connected to the
    6300 via IP.  Here are my DAX settings.
  • N2FA
    N2FA Member
    edited March 2018
    Jim,
    That was the fix. DAX will not start up properly with the SmartSDR program. I had to close it and open it back up while Smart SDR was launched. I had restarted everything and I can duplicate the issue every time. I guess it is a bug or conflict I will pass on to support.
    Thanks for the fast answer.
    73's
  • Bob N7ZO
    Bob N7ZO Member ✭✭
    edited December 2016
    Paul,
    I think I am seeing the same problem in 1.3.  If I close and restart SmartSDR, then I must also close and restart DAX to get correct functionality.
    I did not see this problem with the last version.
  • Karl KB2AS
    Karl KB2AS Member ✭✭
    edited March 2015
    With the DAX control panel open, disable and re-enable the desired stream is all that is required. It is not necessary to close and restart DAX.
  • N2FA
    N2FA Member
    Thanks Carl, that works great also.
  • N2FA
    N2FA Member
    edited August 2015
    Sounds like a bug to me. I'll report it to support.
  • Jim Gilliam
    edited May 2015
    I think this is the most reported problem and Flex should be tired of hearing about it.
