Love Profiles while Remoting
KY6LA_Howard
Member ✭✭✭
I am on an extended 6 week trip and currently iPad remoting from St Moritz Switzerland in to my 6700 in San Diego Before I left I set up several different profiles including 20M. Jt65 20M. SSB Skype 20M. SSB. Parallels Access To name a few. Boy has Profiles made my remoting life so much easier. Instead of clicking buttons all over the place to change from JT 65 to say SSB, I now only click once on Profiles and everything immediately is set correctly. No more mistakes due to forgetting to set DAX to the correct channel, etc,etc. Thank you Flex for making a much more powerful Profiles feature than any simplistic Legacy Radio Band Stack. When Flex finally gets a feature right you really get it right.
6
Howard,
great to hear. Despite being not so much on the road like you, I enjoy using my Flex remotely with the same setup like you (Flex/iPad/Logitech BT HS/Parallels Access).
Would you share your SSB Parallels Access profile? My configuration (audio) does not work perfect yet.
VY73 es mni tks in advance
Tom
DK1EY0 -
Here is a link to the configuration file for my Parallels Access setup https://www.dropbox.com/s/8cgnh8z29xox01w/SSDR_Config_08-27-14_12.13_AM.ssdr_cfg?n=107400531
Many thanks!
VY73
Tom
DK1EY0 -
Your welcome. Worked a KP4 just Before i exported it so i know it works well.0
Howard, you must have platinum cards on almost every airline on the planet, hi, hi....0
Is there a way to create an additional audio device in Parallels so that I can operate ssb via ipad and not lose Windows sounds when operating from home? Or at least not have to reconfigure? Thanks!0
Just America AAdvantage. Plan is to travel as much as we can while we are physically able.0
When u shut down Access from the remote location, the base PC sound reverts to default sounds.0
- 384 Community Topics
- 641 The Flea Market
- 148 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 280 FLEX-8000 Signature Series
- 960 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 798 Peripherals & Station Integration
- 142 Amateur Radio Interests
