CWL Sidetone goes to 100 on band change
Steve N4LQ
When using CWL I can set the sidetone at 550 (my favorite pitch) but if I change bands the Pitch slider goes to 100 while the actual pitch remains at 550. This doesn't happen when using CWU.
Bug?
Bug?
This has been previously reported and is in our bug tracker for investigation0
Experience the pitch set to 100 after start up/reboot of software most of the time here. Usually works fine if I reset it to normal 750hz. Keeps that til I shut down radio or reboot sdr program....I can change bands and all stays as should be til power down essentially.
Seems to do it most or all the time when restarting radio/software.
Also, note loss of audio out at times from either speaker/headphones ....some time one or other or both. Restart fixes that.
Hope this helpful Tim. I am sure you have your share of bugs to track down and resolve.
Carl / K5HK0 -
Tim,
Checking closer on the pitch 100 problem and now notice it reverting back to 100 when I switch to a new band or back to the same bands that I had set it to 750 previously. So looks like more of a presistant problem than I suspected. Hope others have given you many more detailed report of this.
73/Car/k5hk0 -
All comments are helpful. Thanks.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
