Display problem!
SV1JSO
Could you please explain to us why you downgrade the display resolution of panadapter with 1.3?
From a solid pixel now is a pixel plus a shadow or a pixel and a half. It looks ugly!
I am not aware of any changes that would explain this. Could you post a screenshot showing the problem?0
Could this be what you're talking about? The cw peaks are jagged. I'm not sure if this changed in 1.3 but for some reason I did notice it.
Version 1.2
Version 1.3
Regards
Ok...That's magnified but similar to what I see here. Very low res.0
These screenshots are very helpful. Thanks.0
I noticed the same thing here, seems much more jagged with 1.3 on my 6300 Tim NZ8J0
Look for the astigmatism control and give it a turn.0
We have entered this as a defect in our bug tracker to investigate further. Thanks for the detailed pictures; that help a lot.0
An update here: We found and fixed this problem internally today. We'll have the fix in the next release. Thanks for the reports and good info.0
What causes the test pattern in the back ground? I see this on my 32" HD
Sharp tv that I use for SSDR. Who do u get rid of it?
Thanks Terry
K7NY
I am asking about the circles in the background of the SSDR program. Is anyone else seeing this, it looks like a test pattern of some kind.
Thanks, Terry
K7NY
I have a feeling that the answer is "that's how it is designed", but I'm not entirely clear on which thing you are pointing out. There is a grid layered on top of an oval gradient which has a highlight on the screen. Is this what you mean?0
Do you mean the faint blue shading circles behind the grid? I think that is just an artifact of the gradient background fill color.0
Yes that's it, I wasn't sure if it should look like that or not. I have seen it for a long time. Now I know nothing is wrong with the machine.
Thank you
Terry, K7NY
That's what I am seeing is the oval gradient in the background. Now that I know it is normal I will stop worrying about it. The ovals are pretty lite on this machine, I will try and darken it up.
Terry
K7NY
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
