NVIDIA GeForce GTX 260M
Ricky
Ok I downloaded the PowerSDR Version 2.7.2 and the Buttons are overlaping and some are just plain missing and the alignment on my screen is off. When you look at the band buttons like 60m i get the 6 and only half of the zero on the screen...Any thoughts as to how to fix this ?
Make sure that the text size setting is for 100%, this can happen when you do medium (125%) or large.2
Same happened to me a few weeks back. Mine happened to be on a Win 7 64bit new-build PC. Neal's suggestion Is most likely the correct fix. There was another thread somewhere that also tackled this issue.
This Help Center article will fix your issue
http://helpdesk.flexradio.com/hc/en-us/articles/202118448-How-to-Change-the-Display-DPI-settings-for...
You all were right it was set at 125 not 100..Problem fixed thank you all very much.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
