The calibrate frequency offset not being saved in V1.3
k0eoo
Member ✭✭✭
I checked and the calibrate frequency offset is not being saved in V1.3 even if I save a good value using the global profiles. This issue first showed up in V1.2.1.7. I did not see any reference to this in the V1.3 release notes. Running 6500, PC W7.
Please check the following:
https://community.flexradio.com/flexradio/topics/6700-radio-setup-wwv-calibration
Ed, K0KC
Thanks Ed, I did the persistence reset Tim described but after a calibrate and restart my 6500 is still off WWV until I do the cal again.... The persistence rest worked because all my setups were lost....
Yeah, I was not happy to lose all of my persistence settings as well as a number of profiles that I had set up, but that is life!
Ed, K0KC
Exported profiles can be imported after a persistence reset. Doesn't cover every thing but helps.
AL, K0VM
But I did not think to export first...big dummy, Ed!
Ed, K0KC
Yeah, I know.. done the same thing myself..
AL, K0VM
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
