QSK Delay does not work with CWX
kc7cm radio
On my 6500, QSK delay (I like lots) works fine with my paddle plugged into the front panel, but it does not work with the CWX canned messages. It tries a bit when I vary the delay control, but it does just not make it. Is there some other control for CWX that I missed ?
CWX has it's own delay and speed controls. Delay is at the top of the CWX Setup screen0
I just double checked and QSK is the same with CWX as it is with a paddle. Did you have BOTH delays set for zero?0
Found it - sorry - bad eyesight
Thanks !
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
