QSK Delay does not work with CWX
edited March 2017 in SmartSDR for Windows
On my 6500, QSK delay (I like lots) works fine with my paddle plugged into the front panel, but it does not work with the CWX canned messages.  It tries a bit when I vary the delay control, but it does just not make it.  Is there some other control for CWX that I missed ?
Welcome!
  • Administrator, FlexRadio Employee admin
    edited March 2017
    CWX has it's own delay and speed controls.  Delay is at the top of the CWX Setup screen
  • Member ✭✭
    edited September 2015
    I just double checked and QSK is the same with CWX as it is with a paddle. Did you have BOTH delays set for zero?
  • Member
    edited September 2014
    Found it - sorry - bad eyesight
    Thanks !
