1.3 Level Meter miscalibrated for DAX?
Bob N7ZO
When using audio from DAX, I cannot get the set RF power until the main level meter bar (on the SmartSDR "P/CW" panel) is all the way up to zero and the peak indicator shows way into clipping. This is new behavior to 1.3.0.
In this particular case, I am using the Tune signal from WSJT-X, which is just a sinewave (1307Hz for my current WSJT-X setting, but the problem does not seem to be dependent on frequency ).
The frequency is 50.276MHz and RF power is set to 50W and I need to bring the level up as shown to get 50W:
If I set the level as recommended (manual section 25.3.3) I get 17W:
5
I too am seeing very poor drive with DAX enabled.
On RTTY this morning trying to work Viet Nam and couldn't get good drive. Reverted back to 1.2.17 and normal output.
Dave, wo2x
Same here with PSK via DIGU!0
Bob - can you provide a screen shot of your DAX Control panel so I can get a complete look at your setup?
I have seen a problem with DAX and SSB drive levels related to the use of profiles..
May I suggest that after you use a profile to set a digital profile that you either toggle the mode to usb and then back to DIGU/U or deselect and then reselect TX for the slice.
If you have not used a profile, You may find that toggling the TX to something differentt and then back will restore the TX power output for DAX
AL, K0VM0 -
Tim, as requested (captured during transmission):
Hi Al,
Yes, I have noticed some oddities directly after loading a profile that requires toggling modes and TX to clear up, but I have not been able to characterize them yet. The results I am demonstrating here are after the toggles to get things working mostly correctly.
Thanks. I am looking into this0
What is the level of your digital mode source?
I am using Fldigi that is putting out 0 db of signal on transmit in PSK31 mode. In this configuration with the DAX Control panel TX input set at 51, the level meter in both DAX and on the SmartSDR console shows it almost hitting 0 dB. At these levels I am putting out 95W peak into a dummy load. The power was measured by a PowerMaster wattmeter.
I think your audio source gain level may be too low.0 -
Tim,
This is the same WSJT-X program and same WSJT-X settings as I have been using successfully with earlier releases of SmartSDR. I have my DAX transmit gain set to 41 and, as you can see, I am getting full scale metering on the DAX panel and full scale metering on the SmartSDR panel.
I'm not sure what you mean by "your audio source gain level may be too low".0 -
Hi Tim,
I am using DM780 which is set to 0 dB out. TX level on DAX channel 2 tx is 44 which gives peak indicator in SmartSDR just under zero (any higher and it would turn red on peaks). Power in SmartSDR set to 45 and only get 15 watts out.
Same exact settings in SSDR 1.2.17 gives 43 watts out.
I've just completed loading a clean OS image into my test PC and going to install SSDR 1.3 with DAX and CAT clean, no prior versions installed. Will see what the results are...
Dave, wo2x
What I have seen is that the Power Output is lower, relative to the level meter immediately after booting the radio into a persisted DIGI mode and it remains low until a TX profile is toggled....
Output can also become low following a change of mode i.e. DIGU>USB>DIGU... again toggling through a different TX profile will correct
AL, K0VM
Following Al's suggestion, I started playing around with changing the TX profile. Now I think I have arrived at a second incorrect state. With the output set to 50W, I am now getting 36W and strangely, the Compression meter is showing compression even though I am in DIGU mode with DAX audio selected:
BTW, I am measuring my output power with a trusted LP-100A meter that usually agrees with SMartSDR's power output setting (although I find SmartSDR's RF power meter a bit optimistic).
LATE INFORMATION: From the above state, if I toggle the Slice's mode to USB and then back to DIGU, I am back to 17W, but the Compression meter no longer shows any compression.
I am not making any changes to WSJT-X or the DAX panel.
Bob, Here is a screen shot of how mine runs ( normal )
Signal is from WSJT-X with its Pwr slider set at mid scale, DAX slider is set at default (44)
Not sure what the difference is.. I have a 6500 .. If you have not already done so, export you profiles and do a persistence reset, import your profiles.
At this point the output may be low, toggle to a different profile and back again.
AL, K0VM1 -
Same issue here when trying to run WSJT-X. Very low power output. The problem seems to be related to DIGU mode.0
Ross,
A work around ( maybe ). If you have not already done so, save a TX profile of you current digital ( WSJT) operation state. Select some other TX profile and then reselect your digital (wsjt) TX profile. Might restore your wsjt output power..
AL, K0VM
Thanks for the info Al. I will try that and see what happens. I have not had much time to play with yet.0
Followed the work around above from Al that appeared to do the trick.... using my 6500 and HRD tnx's...
There is something going on with the transmit levels. We have a defect listed for it and are actively investigating it.0
Thanks Tim.....0
Just an observation I have to be careful cos limited to 10 watts, but not realised the power level was wound right up on one band and my digital display on my power master showed 110 watts on my 6500!!!!!0
Hi Al,
Thanks for the suggestions, but none seem to help here. And I did the persistence reset before I realized it wiped out all my profiles. (grrr...) Now I use import and export.
- 319 Community Topics
- 576 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
