Profile Manager Issue
Alan Nusso, N4BV
When I save a profile with two Panadapters displayed, when I click on it to return to it, I comes
back just the way it original was with the panadapters and waterfalls in the same position.
When I save a profile with only one Panadapter it returns with the frequency setting and other settings as they originally were but the position of the Panadapter and waterfall are not saved.They return as they do when radio is turned on with no profiles with the Panadapter small on top and the waterfull large. It also does not then save the other Panadapter settings, such as size and position of waveform. Is there a way to correct this, am I doing something improperly?
I wonder if it isn't being saved. Do you assign a profile name? Is the name listed below; in the profile manager? Check out pages 48 - 52 in the software manual0
Yes to both questions
Thanks0 -
You are not doing anything improperly. Global Profiles save the "radio" state, not the configuration of GUI (display) elements, since the radio can have multiple types of clients connecting to it.
Refer to the answer in this post for more detail:
https://community.flexradio.com/flexradio/topics/saving_panadaptor_profiles0
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
