6300, v1.3 and some noise
Randy Diddel
After a successful update to SmartSDR v1.3, I am very pleased with the Profile functionality. FINALLY a radio that can save individual TX settings for those of us that have an amp. I was able to quickly set up a profile for each band with the correct drive power. I also setup a profile for JT65 and another for PSK31. This makes the radio very usable! I am just returning to SDRs (owned a 3000) and got my 6300 last Tuesday. I am really impressed with the improvements. The radio is sooooo much easier to listen to and operate.
I did notice a bug. When I opened a 2nd Panadapter, a lot of what I would call static or distortion appeared in both audio channels. I tried: shutting everything off (SSDR, logging, computer, etc.) Turned computer on and fired up everything again. No change. So, I did that again and this time I shut the power off to the radio-this way I could tell if it was the radio or computer. After the power cycle of the radio, the noise went away. I am not sure where or how to trouble shoot this issue. I will try to reproduce it again after dinner.
/randy
/randy
You should really look into DDutil. It will automatically adjust your AMP drive levels as you change bands. It provides a lot of other functionality as well.
Jon...kf2e
Jon, I already have DDDUtil. Did not notice that functionality. I use DDUtil for my SteppIR BigIR vertical. Will look at it again.
/randy0 -
Make sure you adjust agc-t for each receiver. If the gain is way up it will sound noisy 73 W9OY0
I believe it is called Autodrive. It is on one of the tabs. What's nice is you can have two sets of drive values. One for when you are operating your amp the other for when you are not.
Jon...kf2e
Randy - sometimes after an upgrade, you need to "cold boot" the radio (see the release notes on this) to fully reset all of the processors in the radio. Let us know if it comes back0
- 303 Community Topics
- 562 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 153 SmartSDR for Maestro and M models
- 381 SmartSDR for Mac
- 253 SmartSDR for iOS
- 240 SmartSDR CAT
- 176 DAX
- 363 SmartSDR API
- 8.9K Radios and Accessories
- 82 FLEX-8000 Signature Series
- 878 Maestro
- 47 FlexControl
- 850 FLEX Series (Legacy) Radios
- 827 Genius Products
- 429 Power Genius XL Amplifier
- 290 Tuner Genius XL
- 108 Antenna Genius
- 258 Shack Infrastructure
- 179 Networking
- 423 Remote Operation (SmartLink)
- 132 Contesting
- 671 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 907 Third-Party Software
