Transverter interface connections
GI4FZD
GI4FZD Member
I have a 70mhz transverter which has separate tx and rx connections and needs 0db drive ,am i right in thinking that the transverter output on the 6300 switches between tx and rx and therefore I need a transverter with a single connection or did I read the info in insider wrong?
Cheers
Paul
GI4FZD
  • pa0bie
    pa0bie Member
    edited April 2017
    As You use XVTR for transmit and RXA or RXB for receive on Your FLEX it will work with Your transverter.
    Good luck, Jan , pa0bie.
  • steve.linton%virgin.net
    edited April 2017
    your transverter is ok , the transverter out put on your 6300 does tx and rx,you willuse it to tx only to rx use one of the hf antenna sockets   on mine , iget no output untill i use the tuner (you may not have a atu) also sometimes i have to repress the TX button   hope thats usefull steve
  • GI4FZD
    GI4FZD Member
    edited June 2016
    Thanks Steve,
    See comments regarding rf at ANT1 and ANT2 in my reply to Jan, If i use Antenna 2 for transverter, is it ok to tx on ANT 1 for hf and still leave transverter RX connected to ANT2, there will be no leakage or crosstalk to damage the transvert on ANT2.
    With other rigs i would usually feed transverter to seperate RX only connections and
    I am just a bit worried about blowing the Transverter front end.
    Cheers
    Paul
    GI4FZD
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    edited February 2017
    Paul,
    Technically, the software will allow you to use ANT1 or ANT2 for the receive port of your transverter (see image below from a FLEX-6300).  In our documentation, we are stating that you cannot use a split IF transverter on the FLEX-6300.  The rationale is that with a RX IF port of a transverter plugged into the ANT1/2 port of a FLEX-6300 opens up the possibility of transmitting 100W of RF into your transverter receive port and harming the transverter.  So the recommendation is to convert to a common IF transverter, but you may use ANT1/2 at your risk.
  • pa0bie
    pa0bie Member
    edited September 2014
    I now understand that the 6300 has no RXA or RXB ports/loop.
    In that case I would prefer to use a seperate coax relay intern in the transverter or a external coax relay.
  • GI4FZD
    GI4FZD Member
    edited April 2017
    Thanks Steve,
    I will maybe look at modifying the transverter just to be on the safe side.
    It's better being safe than sorry as they say..
    Cheers
    Paul
    GI4FZD
  • GI4FZD
    GI4FZD Member
    edited June 2016
    Yes i think I have arrived at the same conclusion, a little bit of modification to the transverter should do the trick.
    Thanks again
    Paul
    GI4FZD
  • Robin Haighton
    edited October 2016
    Sounds like a great idea , I have been using dax lab and wou welcome an integrated version with Smart SDR
