MMSSTV noise where there shouldn't be - DAX
Greg
Anyone try SSTV yet with MMSSTV? I am using DAX channel 6. When I set the dax to zero (no audio) i am still getting noise on the SSTV display. Please see included pic.
Thanks and 73
Greg
Thanks and 73
Greg
Looks alot like Jt65 when you dont open the receive filter up wide enough. Increase your receive filter width I bet that clears up Mike N9DFD0
My point is that I have the DAX RX channel all the way to zero. I would expect there to be no noise on the display.
DAX is still very unstable too. Sometimes it works, sometimes it doesn't. I often have to close down DAX and restart it to get it going again.
Greg, there is a previous thread from my friend Larry regarding his inability to decode PSK 31 unless the signal is very strong on his 6500. He tried running SSDR on another computer and decode was much, much better. His conclusion is that DAX on his main computer is injecting noise. He hasn't had time to try uninstalling DAX and reinstalling but perhaps that is an option. Bon Chance!0
Have been running DM780 ,DDUtil ,and my 6500 , and dax since dax functioned.
Running PSK31 the 6500 / DM780 will decode signals not even enough to show on the waterfall. Finding a clear space is the usual.
Also it is on one machine. There is no noise generated from my computer or Monitor .
The issue of DAX failing to start or you turning it off .I believe that someone reported this possible problem and it was not a "Clean install"
What I have seen is multiple computer Hacks /hijacks etc in this computer that really screws everything up. Today's computer Thief's out there make it absolutely necessary to continually run the various Cleaners / Malware / hijack software find and destroy programs . This keeps everything working
So for a suggestion I would remove your programs Campaign with the various computer clean up programs . Get your computer running 100% and then reload Flex etc.
I have exactly the same spectrum on the display from MMSSTV as there is no signal on the input. This is done by the large range AGC in MMSSTV and shows the noise generated internal by the PC.
Al kind of third party programs as MMSSTV , Whisper and Opera are unstable in the use of DAX channels. If I start any of this programs , then sometimes the previous set DAX channels are changed to a random other number. The same experience has pa0wmr. We think that this problem is not related to SSDR or DAX but to the PC and/or the third party programs.
Greg did you ever get this resolved. I can get the receive working fine but can not figure out how to get the tx audio setup.
Bill
VA3QB0
- 654 The Flea Market
- 384 SmartSDR API
- 51 Aurora
- 967 Maestro
- 938 Genius Products
