Audio recorder ssb
on5po
HE/IT remains just to me has find how to have AUDIO RECORDER,pitcher of call to have a flex 6300 in suit use as my 5000A Who could explain myself or could find the audio recorder in the flex, or how to use the audio recorder of DM780
tks 73, Janny
tks 73, Janny
Janny
The record/playback works just like the Flex5000... only difference is you can't save the recording to the computer.... Round red button to record and green triangle to playback
Thank you John, I tried, click on red button to record to push on ptt to record my call, click green triangle to listen,--> not of sound doesn't function ,doesn't pass also in xmt
I suppose that me work well, thank you to give me more of explanation
Janny0 -
John, That only functions has record the conversations, the that functions
I recovered the registration of my 5000a he/it doesn't record himself/itself
Janny0 -
OK
Pressing the ( red button) starts the recording . (What you are listening to on the frequency) You then must press the ( red button ) Again: ( Finish the recording )
Then when you select the (green play button) it will play back .
If you wish to record your transmission you then must first press the ( red button) press your PTT when finished release your PTT and again press the (red button) to complete . Play back is by pressing the (green button) .
Like Others have stated this recording is not saved to an accessable file (YET)
On a related note there is an idea to add an option for the recorder to work like a "black box" recorder on a plane. It would run in a continuous loop recording the last several minutes until you stop it. It has 5 votes so far and here is the link.
https://community.flexradio.com/flexradio/topics/black_box_recording_add_a_looping_option_to_the_rec...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
