I don't have a channel 2 in TX , only in RX
on5po
on5po Member ✭✭
edited January 2018 in SmartSDR CAT
I don't have a channel 2 in TX , only in RX I have in smar sdr CAT,1 port dedicated and 1 port PTT rts it is necessary to take a second PTT port so that the slide B is also in TX I use HRD 6.2 and flex 6300 thank you to help me
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    Not sure what you are referring to.  Do you mean you have no Xmit in the DAX control panel?  Give us a few more details...
  • on5po
    on5po Member ✭✭
    edited January 2017
    yes, not of xmit in Chanel B in the DAX  if I want to have the Xmit in B, I place chanel 1 then in B,bud on A,  no  RX in HRD watherfall, and chanel becomes none
    Janny
  • on5po
    on5po Member ✭✭
    edited March 2017
    to work in split with HRD   on DAX B I light TX and chanel none
    in DAX A,chanel 1
    with TUNE, split--> OK xmit
    with macro (rtty) HRD, no xmit in smart
    does the problem come certainly of the configuration in HRD???
    how to keep the RX in watherfall (HRD) and TX in B smart
    sorry, not easy to explain in English
  • Tim - W4TME
    edited December 2016
    "on DAX B I light TX and chanel none"
    You have to have the DAX channel enabled to pass data through it.
    The best way to work split in digital modes is to use one slice and change the TX frequency with XIT
  • on5po
    on5po Member ✭✭
    edited January 2017
    TKS you are the best
