I don't have a channel 2 in TX , only in RX
on5po
I don't have a channel 2 in TX , only in RX I have in smar sdr CAT,1 port dedicated and 1 port PTT rts it is necessary to take a second PTT port so that the slide B is also in TX I use HRD 6.2 and flex 6300 thank you to help me
Not sure what you are referring to. Do you mean you have no Xmit in the DAX control panel? Give us a few more details...
yes, not of xmit in Chanel B in the DAX if I want to have the Xmit in B, I place chanel 1 then in B,bud on A, no RX in HRD watherfall, and chanel becomes none
Janny0 -
to work in split with HRD on DAX B I light TX and chanel none
in DAX A,chanel 1
with TUNE, split--> OK xmit
with macro (rtty) HRD, no xmit in smart
does the problem come certainly of the configuration in HRD???
how to keep the RX in watherfall (HRD) and TX in B smart
sorry, not easy to explain in English
730 -
"on DAX B I light TX and chanel none"
You have to have the DAX channel enabled to pass data through it.
The best way to work split in digital modes is to use one slice and change the TX frequency with XIT
TKS you are the best0
- 374 Community Topics
- 102 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
