DAX Driver will not start even after new SDR install
Ron Morgan
DAX does not work. An error message occurs during the installation process of Smart SDR 1.2.17
Several complete unistalls, plus I cleaned pout old programs including MicroHam, and anything that might use a port.
DAX Control Panel v1.0.5.65 Audio is seen on the display. The TX indicator is ON. The #1 indicator is GREYED out (That is the error). Any ideas?
After uninstalling, Check in Device Manager, check "show hidden devices" and remove all old instances of DAX ports - there are probably several. reboot, reinstall.0
You are wise beyond your years. Another complete uninstall, Device Manage Hack and now all is well. At least that part of my life. Now to get N1MM to key teh radio. May need to buy a K1EL Winkeyer.0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
