Will not connect
Alan C
Windows 8.1
Power up the 6300, no problem. Start up SSDR (latest) 6300 shows in the chooser. Click on it and then hit connect. Nothing happens, then goes to "not responding". I have rebooted the 6300 4 or 5 times. I have re-booted windows 4 or 5 times. No change. It was working yesterday.
And I just un-installed SSDR and re-installed - same result (not responding)
update:
I just downloaded another SSDR installer - and put it on my Windows 7 laptop. I get the same thing - Not Responding. I have re-booted everthing - same result
Are you connecting directly between the radio and computer, or is there an intervening switch/router? Try a direct cable, and while you're at it, maybe a different cable. Reboot both and let's see what you get.0
thx, George
I'm connecting through a GB Switch. As I mentioned, it was working yesterday (and prior days). I will try your direct connection suggestion
Tried direct connection. Same thing - Not Responding. 6300 shows up normally in the chooser.
I'm thinking my 6300 is defective (had it about a week).
Try a factory reset and removing the power for 5-10 minutes (physically disconnect the power supply). Sometimes that will kick things back over. Also - is your LAN card set to a specific IP? Try it without during a direct session. Good luck!!!
Sounds like the 6300 network did not see your network DNS and assigned the internal network address. You will see this result if the PC and radio are on different subnets.0
Stan, I almost understand. How to resolve then? thanks
Your ethernet cable OK?
OK, George's suggestion of disconnecting the power cable for 15 minutes WORKED. Now why did all that happen? Pretty frustrating.... Thanks, George!!!
Long power disconnect clears the radio's connection state and allows a fresh start. Glad it worked, Alan!! See you on the radio...0
I have a NetGear switch (12V supply) mounted in my rack with the 6700. If I turn on the 12V battery lead and don't wait for the switch to initialize before powering up the flex, the flex tries for a network address from my main network and fails - resulting in the local address.
SSDR will "see" the radio but, since it is now on a different subnet, will not connect. SSDR currently hangs; appearing like the radio is not there but still appears on the list.
The flex only resets its network address on a simple power on; requiring a power off and power on with the network available (access to my DNS).
My lesson - Leave power on the network switch. Eventually the flex may be assigned a static address and this problem goes away.
Alan - as per the SmartSDR release notes, a cold boot of the radio (removing power) is recommended as a best practice after a software upgrade to ensure that all of the internal processors reset.1
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 195 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 744 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
