My Flex 6700 DIGIU will not work with Line in, but OK using USB
W5UN_Dave
On 2 meter eme transmit cycle I use MAP65 on another computer to send transmit tones to my 6700 through the LINE input. If I use the USB mode, all works OK. If I choose DIGU mode. there is no input signal from LINE detected. Not a big problem, but shouldn't this work with DIGU mode also?
Perhaps someday FLEX will have a proper IQ receive signal to work with MAP65.
Did you change the audio input (dropdown) to ACC when in DIGU mode?0
Hi Tim, No, should I? Wonder why?
Because you need to select the proper input for it to work. The ACC button is for mixing the selected input from the drop down with audio input from the ACC connector. This is for doing things like interfacing with a voice keyer on phone modes. If you want the ACC connector to be the primary input, you need to select it from the drop down section.0
- 113 SmartSDR+
- 944 Maestro
