flex 6300 ,1.2.17,with DM780 probleme instal only after 3 minute
on5po
on5po Member ✭✭
edited March 2017 in SmartSDR for Windows
problem instal DM780 stard with flex 6300, only happen to biting 3 minutes   as all change of frecence ,3 minute after on DM780
I tried DDUtil, without result,
I have 1.2.17 with I7 64 bits
who has the solution
Janny
  • Reg
    Reg Member ✭✭
    edited March 2017
    Janny:
    If you are only trying to use DM780 with the FLEX-6300 using DAX then Chris K6OZY posted an excellent setup guide, with screen shots, which you can find at:
    https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide
    Si vous avez besoin d'aide en français, vous pouvez me contacter hors ligne à aa5gi@arrl.net. Bonne chance.
    Reg
  • on5po
    on5po Member ✭✭
    edited August 2016
    I tried with ddutil, and minidelux, without result,   now impossible to connect to HRD
    I would not need an explanation doesn't have for the 1.2.17 and 6300
    thank you
    Merci Reg ,je vous attend avec impatience , on5po@hotmail.fr
    Janny
  • Tim - W4TME
    edited December 2016
    Try the latest version of HRD.
  • on5po
    on5po Member ✭✭
    edited August 2016
    Hello,
    finally we have found how to make operate flex 6300 with DM780  remain has find, MON--> no audio
    chanel 2 doesn't function, how to make operate it for RX B
    thank you to help me
    Reg, les mails me sont retournés ,problemes avec votre adresse mails
    janny
