6700 Just keeps on Running
Roger Rockwell/na4rr
I don't know if I should report this as a problem or if its a new feature. Didn't see it in the release notes. This has happened a couple of times but I don't know what to do to reproduce.
Flex 6700 SSDR 1.2.17. Win 7
I'll have the radio on running SSDR 24/7 and all is working fine. I come come back to the shack after being gone as much as a day. The radio is still working but SSDR is gone from the computer. My SSRD icon is gone. I open Task Manager and SSDR is not there. I turn the computer off but radio is still running. I even remove the cat 5 from radio to computer. The radio works even xmits with no computer. If the display on the front of the radio would read the freq and mode I would actually like this. I have thought that it would be a good option to set everything up and then be able to disconnect the computer. Of course if I power down the radio all goes back to normal.
Roger
Roger
This is a known problem that was supposed to have been fixed in the latest release update. Like you I still have the same issue so it was not fixed.0
Maybe this feature is a hidden prelude when the radio will be a stand-alone remote. I love the frequency readout idea.
Jim, K6QE
OK and thanks for the reply. That's what I get for not keeping up with the Community for the last couple of months and not digging into past posts. Like I said I would actually like it if you could do it on demand. I could see it being handy to be able to set the radio up as an emergency radio on a set freq with no computer..
roger
I was playing with an older XP machine when that happened to me on the previous release. I thought it was pretty cool to be able to receive with no computer. So all we need is a front panel. I recall the TenTec Pegasus....Then they decided to put a front panel on it. Originally it was called the Pegasus FP but changed to Jupiter upon release.
Steve N4LQ0 -
We have this issue listed in our bug tracker.
Since the radio's operating software is completely "self contained", it does not require to have SmartSDR connected and running to operate. If SmartSDR is crashing, I'd look at your PC for a possible reason. Such as is it going to sleep or hibernating? Did Windows do an update and force reboot the computer? We just don't have many reports of SmartSDR for Windows crashing when left idle unless there is a PC problem of some sort.0 -
Check your power saving settings...ethernet card, WiFi port, disk drive, or USB port powering down, as well as virus protection scans, windows update auto-reboot, etc. may all be sources of difficulty, especially the ethernet port and auto-rebooting updates and virus scans, which caused me some difficulty a while back.0
Yes I am sure something in the computer is "going to sleep" I just haven't tracked it down beyond the normal stuff. I just had not experienced SSDR going completely away and the radio still playing. My Win 8 laptop is worse The panadapter will still show on it. but locked. I have turned off everything I can find that times out or goes to sleep. Hard drive always on, no screen saver, performance high, display always on. Sleep-never, Hybrid sleep-off, Hibernate-never,Allow wake timer-disable, usb suspend setting- disabled, Lid closed-do nothing, Multimedia setting-prevent idling to sleep, low battery action-do nothing. I have Windows auto update turned off.
roger
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 37 Aurora
- 947 Maestro
- 924 Genius Products
