Should Service Release 1.2.17 be pulled?
Jay -- N0FB
Jay -- N0FB Member ✭✭
I have worked in the software industry for nearly 30 years.  I have been part of many software development releases. One thing is clear:  When old problem are fixed, new features are added, and few new problems emerge, the user community welcomes and even extolls the virtues of a new software release. Unfortunately, sometimes things go awry with a release and be caused by intended consequences.  Even though all companies do their best to test every conceivable item, invariably something sneaks through. It doesn't happen often, but sometimes the enormity of the new problems caused by a release supersede the value of problems fixed or new features provided.  This happens to every software business and FlexRadio won't be immune to this axiom.
I understand.  It's always hard for an organization to admit a stinker when it is obvious to everyone that the proverbial rotten egg has been laid (I give you Windows Vista).  It is at this very point one gets a glimpse of a company's true mettle.  Does the company try to ignore the problems; hoping it will go away and (causing more customer pain?) Or does the company take the high road and acknowledging that the new problems identified in the release cause sufficient pain (for customers and for the company's own technical support department) to warrant a roll-back to a previous release.  One of these roads show true customer focus and garners respect.
With the number of problems threads popping up on this specific release, should SSDR 1.2.17 be withdrawn or does it add enough value to sustain working around the newly found issues?  I merely ask the question.
«1
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited June 2020
    I have not run in to any issues that would indicate it should be pulled.  One can always downgrade if there are major problems.
    Andy K3UK
  • John n0snx
    John n0snx Member
    edited December 2019
    Jay
       If you have been in the software industry for 30 years, then you KNOW that the absolute best case scenario is to hope to satisfy SOME of the people SOME of the time.... It is in OUR nature to gripe and complain about any and everything that is not exactly the way we want it.  What is an issue for some will not be an issue for others....  Just because someone post a problem they are having doesn't make it a bad build.  This is a hobby and there is a lot of experimenting that happens with the hobby. Some work and some don't. FRS has done a great job and my hat is off to them...They will continue to improve the software as needed because of the feedback from the users.  It's called progress....We all would like this perfect little world but it just isn't going to happen.
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited May 2018
    I have not seen any new problems yet, and have even seen some older ones fixed.  The one I reported (slow shutdown) pre-existed this release, and continues to (not) work the same way.  I was just getting ready to post a praise - the CAT upgrades have really helped my DX4WIN connection issues!
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited October 2019
    Now I think we are getting carried away. I am a very heavy user of my ham radio and log hundreds of QSOs a month in several different modes. While I have seen some of the issues that are reported, the radio is a stable platform and works as expected. I have faith that every time a release is done it will improve the radio. I still believe that even after this release. I usually find when I have issues with software it's because I didn't follow directions such as uninstall cat or something else. The software is no where close to needing to be pulled Mike N9DFD
  • Jay -- N0FB
    edited March 2015
    I totally get it John.  If you look at my past comments, I'm not a notable "complainer".  That's just not my modus operandi.
    This is the first service release that I've gone through with Flex and my 6300.  Its easy to note the rash of issues specifically surrounding this release.  Some of these issues are not small or insignificant in nature from an operations standpoint.  These have been generally issues that Flex has added to their list of issues they are seriously looking into....not just some off the wall, end-user error.
    I'm curious to see at what point that Flex makes a statement whether they still recommend updating to this new revision...or not.  From a engineering stand point, it may even be helpful to continue to promote this release so as to see if anything further shakes out.
  • Gerald-K5SDR
    Gerald-K5SDR FlexRadio Employee ✭✭
    edited June 2020
    Jay, I am wondering if you are referring to the corrupted download problem we were having due to heavy downloads on from our website.  I am not aware of any major issues with this release.  In fact, I ran the release last weekend in Field Day with no issues whatsoever.
    Here is the post that Tim made earlier regarding the corrupted downloads:
     Tim - W4TME, Customer Experience Manager
    Official Response
    The issue of corrupted downloads should be resolved now.  We identified that a CPU resource contention issue with our web server was to blame for for the aborted HTTP downloads which resulted in partial file downloads.  Yesterday (yes, on a holiday) we put together an action plan to resolve this issue and very early this morning we migrated the FlexRadio web site to a new server that has much greater CPU resources available to it.  When you visit the web site now you should notice that it is more responsive and should download files a little quicker than before making for an improved user experience.  We apologize for the inconvenience this issue cause and we greatly appreciate your patience and understanding while we resolved it.  Thanks.
  • Jay -- N0FB
    edited March 2015
    I understand Andrew...and I have.
  • Jay -- N0FB
    edited March 2015
    Hi Gerald.  No, Im not concerned with the delivery. Those are things outside of your organizations control.  I understand the difference between net connectivity contention, download problems and software issues.  The more significant issues (in my mind) introduced in this release include audio drops while dragging the panadapter up or down in frequency on 17, 15, & 12 meter bands (more of an annoyance) and the complete audio drop out for 3-5 second when the AGC set to "Slow" or when changing bands or modes...or transmitting in CW Mode.  When AGC set to "Slow" QSK is impossible.
    Yes there is a work around for the later (don't use the slow mode for the AGC setting).  However in the summertime when there are a lot of thunderstorm crashes on the bands, the slow setting came in handy.
    Just so you know, I'm a huge fan of Flex and am tickled to death with my 6300.  I'm also a previous owner of a Flex 3000.  I've given talks and demonstrations of Flex Radio to my local ham radio club meetings.  I've even made a presentation and proposal to our County's Emergency Management department to encourage them to purchase a Flex 6x000 for our county's RACES group.
  • Gerald-K5SDR
    edited December 2016
    Hi Jay.
    I did some testing tonight and was not able to recreate the audio dropouts as long as I dragged inside the ham bands.  I was able to get dropouts to occur outside the ham bands at the exact frequency transitions between wide band segments.  You can hear the filter relays click when this occurs.  For example, this happens at 18.268 MHz and 25.090 MHz, which are well outside the ham bands.
    With regard to the Slow AGC setting, I cannot reproduce the problem on CW QSK.  However, I can reproduce the 3 second lag when I switch from another band or mode.  The lag is not there on any TR mode (SSB, DIG, or CW) that I can reproduce.  I will report the delay on switching band or mode to engineering as a defect.  This is the only condition that I can reproduce.
    73, Gerald
  • W3DCB
    W3DCB Member ✭✭
    Dear Friends:  Why is it that every time that I download an update everything works so well?  Along the way, each and every single new version has successfully downloaded and worked well with one exception which turned out to be operator (me) error.  Yet, I look at the reflector from week to week and see so many complaints and issues.  What am I doing right?  DDUTIL works well for me, each version, and SDR bridge with CW-Skimmer.  HRD works well, each version, and HRD mini Deluxe.  JT65 and DAX along with every other program I have tried just seems to work well with my Flex-6700.  It may take some trial and error before I find the correct settings, but with perseverance, all seems to work just fine.  Am I unusual?  Are those experiencing difficulty just louder than those who seem to fare well?  de W3DCB  Daniel Baral
  • John n0snx
    John n0snx Member
    edited April 2015
    I agree with you Daniel.... some have just got to resist any change at all.... no matter what they will knit pick and find something to complain about....Even if everything were perfect there would be a complaint about that too... I think the new update works pretty darn good.. but that's just my perception... no complaints here....fine job FRS.
  • Mike NN9DD
    Completely agree with you both Mike N9DFD
  • David Decoons, wo2x
    edited May 2016
    Hi Gerald,
    I've had several people confirm that AGC slow is unusable with the static crashes on 40 and 80 meters here in the summer afternoons (when we have storms). Today 1.2.17 would be OK to use since there are no storms forecasted until Wednesday.
    Not sure what mix of beta testers you have to know if anyone is in a similar environment to me on the same bands but this issue was not caught before release. Unfortunately that is the drawback of beta testing is you cannot ever replicate every possible operating scenario. I'll offer to help beta test :-)
    This is a big enough issue that I rolled back to 1.2.1.
    For those not having issues with 1.2.17 I suggest if it is possible to try it on the lower bands during conditions where you get a lot of static crashes. What I and many others have found is the receiver mutes on any signals under S9 +10 with default settings and AGC set to SLOW.
    Dave, wo2x
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    Agree with John, Mike & Daniel. I have never had an issue when upgrading. The digital area works perfect with all the 3rd party software I've tried. All and all I think that FRS is a first class company. Having met and talked to Gerald Youngblood, I know it will stay that way.
  • Asher - K0AU
    Asher - K0AU Member ✭✭✭
    I observe the audio dropout problem with a single slice and single pan on 12M.  Pan visible from 24.895 to 24.920.  Slide the pan left or right and the audio drops in and out.  Didn't stop me from working a great opening on 12M yesterday.
    On 15M I hear minor audio distortion when sliding a pan.
    1.2.17 generally seems more stable than previous releases.
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited January 2015
    This has been my pet peeved since the inception of this Forum.  This individual and others like him have too much time to complaint about any and all issues; no matter whether it works or not.
    I agree with John, Mike and all the others; every service release has improve my radio performance.  And the only thing I could tell FlexRadio System is; keep the versions release coming.
  • Jay -- N0FB
    Ok, guys.  You win.  I'm going to go back under the bridge where most of you must assume that I came from. Administrator, please ****, lock, delete this thread. I'm done.  If I have issues, I'll deal directly with Tech Support.
    FlexRadio is a stellar company.  I love my radio.  I love the releases coming out.  Is everything perfect  No.  Do I expect perfection..no.
    Gerald....my most humble apologies to you and to your organization if I have offended.   W0AVE - QRT!
  • W9OY
    W9OY Member ✭✭
    edited June 2020
    I noticed the dropout he is talking about while tuning on 12M either CW or SSB.  I did not notice it on any other band/mode.  Using a 6300.
    73  W9OY
  • Burch Akin
    Burch Akin Member ✭✭
    edited July 2014
    I see the issue with 12 meters as well. I am also using a 6300.
  • EMIL-DL8JJ
    EMIL-DL8JJ Member ✭✭
    edited July 2014
    Hello
    in my opinion and this case should be not pulled.
    generall, if a new release have the same general bugs like the old one and extra bugs, will be not useful to make it public.
    Better less bugs, than more bugy features.
    Emil, de DL8JJ -  steel  very enthusiastic FlexRadio user:)
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    For the record, I am still using the latest release because it has fixed more than it has broken. I HAVE experienced what I will call AGC "pumping" or "overshoot" and excessive hang time in Slow mode. I have also experienced the audio stuttering while dragging the pan adapter within ham bands, and sometimes when tuning with the Flex Control knob at the end of the screen range while it shifts the pan adapter. While I find these a bit annoying, there have been some additional improvements in CAT and DAX as well as other performance enhancements, so I will just work around these issues until the end of the month when 1.3 is due!
  • Ken - NM9P
    I noticed it too, but don't remember which bands. I was bouncing all over the bands this weekend! 160-6 meters all modes but FM!
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    edited February 2019
    I would love to add my two cents worth, but my 6700 has been back at Flex for repair since before this release (the 2 and 4 meter bars issue plus some strange humps in the panadapter signal). Being without my radio is worse than any new found bugs that might have surfaced. I, too, have worked on large software projects for Shell, so I understand, and I can sympathize with the code writers. There will always be a few bugs. We live in an imperfect world.
    Hello  Flex, please send me my fixed radio.
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    The problem here is terminology. The 12m dropout problem is not while tuning...It's while dragging the panadapter. Doing that on any band causes ripples in the base line but on 12m you can hear it clicking. It's just not muting....The SLOW AGC problem is for real. SLOW is TOO slow. I mean it must have a 5 second decay time. I noticed this while listening to a SSB QSO on 60. One crash of static desensed the receiver so long that I though my antenna had come unhooked! ....The problem I mentioned was with the SWR meter. You fixed the "jumping on transmit" problem but created another one. Here's the deal....I'm using a remote auto ant. tuner. So I change bands, hit the "tune" button on SSDR and my SWR reads way over in the read...So I wait and wait and wait and 15 seconds later it finally slides down to near zero but in reality the tuner did its job in 2 seconds as is evidenced by my external SWR meter. So the SWR meter response is SLOW. That's a problem when using a tuner. One could never get his tuner tuned using an swr meter like that.
    I hope this is clear now. There were other issues but people are not getting the message across so you guys end up saying you can't duplicate it...Well no wonder. Anyway. I'm enjoying 1.2.17 as it is. I'm just working around it until it gets fixed buy at this rate it never will.
    Steve N4LQ (6300)
  • Dale KB5VE
    Dale KB5VE Member ✭✭
    edited January 2017
    Having been involved in post that address a issue with smart sdr I can feel for Jay. Maybe what the thread was headline was a little over the top but he does have a issue and even though 123 people are not having this issue he is. Some times out almost fanatical support for the flex brand can get in the way of what this community was created for. So it would be better for someone who has this problem or has had it and has a work arround to post than 20 who say they have not. There is not a rule to be put in place here but always remember the person has a problem or they would not post. They might be the only one with this problem and if no one post something to help them then the help desk is there to help correct. Jay I know Gerald does not take your remarks personal and I suggest you use the community as it was intended. I do not hesitate to bring up a issue I have. If I do not get a response in a a couple of days I enter a ticket and let the pros handle it. Remember if you are drowning and everyone on the shore keep telling you how good they can swim you still will drown, but if just one says I couldn't swim once and I know how he feels so I am going to jump in and get him. That is what the community is for.
  • Mike_WB8CXO
    Mike_WB8CXO Member ✭✭
    edited February 2017
    Reading this thread was painful. I wonder if we'd treat each other this way in person. Back to that bridge ;)
  • Norm S
    Norm S Member
    edited July 2014
    Hey Dave.  I have what I would call spikes on 2 meters.  They are about every 50 kHz and appear whether I have an antenna attached or not.  I haven't checked 4 meters as I don't currently use that band.
    Are these the same as the bars that you have?  What did Flex tell you about the bars?    Does anyone else have these?
    Norm - W7CK
  • W5UN_Dave
    W5UN_Dave Member ✭✭
    edited November 2016
    Norm, my 6700 is back and the bars are gone on 2 and 4 meters. So are the humps that occupied much of the HF band. It took a return to Flex to fix this problem.
  • Jeff Gray
    Jeff Gray Member
    edited December 2015
    Although I don't have anything running SSDR, after reading the threads on here and else where, several things are apparent. They apply to both PSDR and SSDR.
     1. There is an extreme learning curve. A lot to learn to make it run well.
     2. Need to have computer to handle it IE quadcore proc. 8 gig memory, will run well. If your computer is minimal to meet requirements or less, upgrade your computer. You will be disappointed if you don't. You will also want a good video card in it. A low end video card will not have enough resolution to see the weak stations. This is very important if your into CW and Digimode operating.
     3. Run the installer and update as administrator. Needed registry keys may not be created properly if you don't. Once installed, set SSDR or PSDR to run as administrator. Otherwise the permissions that will allow it to run well may not be there.
     4. Turn off all un-needed TSR (terminate and stay resident) programs. These start with windows. They do that to reduce time waiting for it to load every time it is needed.  IE Skype, Yahoo, MSN  They are located next to the clock. Depending on the version XP Vista and 7 they are an icon next to the clock or in a window that pops up when clicking the double arrow by the clock. As for 8 and 8.1 I have no experience.
    They load into memory and do call checks. They add to memory being used and processor latency degrading performance.
     5. Be sure to create proper exceptions in your firewall and in some cases you may need to tell antivirus the program is safe. Some firewall settings and antivirus programs will limit or block some things.
     6. Backup your current settings. Play with the adjustments till you get them set properly for your hardware. What works on one computer may not work well if at all on another. Then if your not happy go back to your backup. It will reset your rig to where you had it prior to tinkering.
      Hope this helps and see you on the Panafall.
